Author Topic: 1/144th Prometheus scratch build  (Read 52265 times)
Offline Quaralane
  • Overdose
    • Awards
Re: 1/144th Prometheus scratch build
« Reply #15 on: Sun Nov, 09, 2014, 11:35:PM »
Definitely coming together so far.
Offline nicholassagan
  • Mod
  • Overdose
  • sippin on gin + juice
    • Model Portfolio
    • Awards
« Reply #16 on: Mon Nov, 10, 2014, 11:15:AM »
Wow.
Offline Grendels
  • Mod
  • Overdose
    • small business that I own.
    • Awards
« Reply #17 on: Mon Nov, 10, 2014, 12:42:PM »
Nice start!
Offline hook1169
  • Addict
  • "220 221 Whatever it takes" - Mr. Mom , M. Keaton
    • Awards
« Reply #18 on: Mon Nov, 10, 2014, 01:14:PM »
Man this is one of those builds that I will be watching intensely. I have always wanted to build a version of the Sulaco from Aliens. Around 1/700, but my skills are not ready for such an undertaking. Will be watching this closely.
Offline Phil B
  • Recreational User
    • Awards
« Reply #19 on: Fri Nov, 14, 2014, 07:46:PM »
It reminds me the first steps of the MK1. Few tubes, wood and card and 300 pics later... an incredible ship.
Gag, you're totally crazy. Do not change!
modelling & science-fiction
www.cyber-mecha.com/blog - www.cyber-mecha.com
Offline The Nylon Gag
  • Needs Intervention
    • Awards
« Reply #20 on: Sun Nov, 16, 2014, 06:21:PM »
Ello,
Thank you so much friends for such positive works from builders who's work i admire so much
Well enough chit chat........everybody comfortable
Then lets go......
Had a few foam spots to fill,
Sanded with 80 grit on a sanding block for basic shape, we will get finer later, righ now i'm only interested in basic form
Installed two tubes to begin the internals for the rear section, cut to length and screwed in place, with a spacer cut and dry fit on the very back
Added some more foam fill-ins on the rear
Marked,
And cut the forward bulk head
Marked, cut and boxed off the rear section of the forward bulk head
Main body ready for epoxy resin sealer layer
Painted with a layer of resin and left to dry for 24 hours
Marked and cut 1/8 thick styrene to position as key blend/ transition points
Boxed in the forward neck section with 1/8" styrene sheet
Started to box in the rear section
Front,
Bondo'ed up ready to sand
Gunna let it dry real good and then give her a bit of a sand
But thats next time folks
Until then
Stay frosty
Gag
Out
Offline Belugawrx
  • Addict
    • Awards
« Reply #21 on: Sun Nov, 16, 2014, 09:02:PM »
Two projects going at the same time ...
You rock Gag!
Cheers
Bruce
Offline Quaralane
  • Overdose
    • Awards
« Reply #22 on: Mon Nov, 17, 2014, 12:29:AM »
This is definitely rocking, Gag.
Project is well on its way now
Offline Klaus, not Santa
  • Addict
    • (not) Santas Workshop of the Strange, the Peculiar, and the Amazing
    • Awards
« Reply #23 on: Mon Nov, 17, 2014, 04:10:AM »
Wow, this is really massive!
And of course again excellently executed - and as usual I saw two or three new things I can use for myself :)
Thanks!
(not) Santas Workshop of the Strange, the Peculiar, and the Amazing - http://fischers-design-shop.blogspot.de/
Offline LrdSatyr8
    • DavisWorks Unlimited
    • Awards
« Reply #24 on: Mon Nov, 17, 2014, 09:19:AM »
This is looking awesome my friend... can't wait to see more... but there's a couple of questions I got for ya that have been bugging me because I've been thinking of doing something like this (not this ship but scratchbuilding) for awhile and just gotta know.
1) What kind of glue do you use to glue the foam together and/or to the wood?
2) What kind of glue are you using to glue the plastic to the wood?
3) What kind of resin/shellac/polyurethane are you using to coat the foam to seal it before putting the bondo on?
I've tried quite a few different glues but it never seems to hold or do what I want.  Would be a good tip for newbies to know.
I'm almost back to full capacity... still waiting on parts  to be delivered!
    • Awards
« Reply #25 on: Mon Nov, 17, 2014, 07:44:PM »
Well LordS
To stick the foam together i used regular two part epoxy from the hardware store, specifically Devcon home 5 minute epoxy
To stick the plastic to the wood i used Slo-Zap thick CA
The resin is specialty stuff from USComposites.com, its their 635 thin epoxy resin with a mix ratio of 3 to 1.
I cannot encourage you enough, or anyone to attempt a scratch build. This is the first time i have done this process, foam carving, shaping, sanding, sealing and finishing is all new to me as well.
Find a project, be it spacecraft, prop, futuristic weapon, armour, anything that gets you working and thinking outside the box. with out instructions, you will be amazed at how creative you are.
If you are a model maker you clearly have an 'eye', so use it, you know, instinctivly, when something looks 'right', so use your 'eye' and make something that looks 'right'
I'm always here to help
Gag
Offline LrdSatyr8
    • Awards
« Reply #26 on: Mon Nov, 17, 2014, 08:15:PM »
Awesome tips bro... thanks
Offline strokemondeo
  • Just Experimenting
    • Awards
« Reply #27 on: Sat Nov, 22, 2014, 05:43:PM »
looking great there , I'm really looking forward to seeing more of this scratch build , some great idea's there .
"poised in the air, wavering ever so slightly from side to side, the aircraft almost
seemed to ... from Ron Renauld's opening to the novel "Airwolf".
Offline JohnSimmons
  • Staff Writer
  • Overdose
  • For Spud: I was once Merseajohn
    • http://mjscalemodels.blogspot.co.uk/
    • Awards
« Reply #28 on: Sun Nov, 23, 2014, 06:18:PM »
Amazing, and understandable too. I sort of get what your doing lol.
Offline texastony1946
  • Habitual User
    • Awards
« Reply #29 on: Sun Nov, 23, 2014, 08:40:PM »
I am constantly amazed at how creative you are with these out of the box builds. The shape of the
ship is really coming together. I'm starting to see how these pieces are going to work together.
really amazing work and ideas.
